| I think I paid $375 from Deere about ten years ago for ROPS only.
Its the rigid one, and its heavy. I rigged a hoist from the rafters to lift it into place. Then couldn't get the bolts to go in the threaded holes in the plates. Seems they drilled and tapped the holes, then didn't protect the threads while welding the plates to the tubes and so the threads had weld splatter anchored even better by the paint. You may save much effort and cursing by running a tap, probably still 3/4-16 through those holes so the bolts will go in.
Gerald J. | |
