Saronville NE | Since seem to be alot of people steering a guy towards a vertical I have some questions IF I decide to consider one. Ok, if a guy wanted to mix grass hay how long will a single screw take? How does the flighting last in them vs other wagons with augers? Can you overfill a vertical and tear things up? If all your hay is allready ground and you put silae, WDG etc in, and have to walk away from the wagon for a few minutes will it grind things up even finer and cause promblems? Do you replace knives very often? Ive never been around one, so my questions could be endless. | |
