west central Iowa | If you have a spear on your loader you could use it to line up two bales to pick up with the 3 point or you could stab the second bale a little higher to keep from dragging the first one. As far as the height just mount the spear at height you want to be to stab the bale when the 3 point is clear down if you want the max height when it is picked up. You could also use four of the lighter duty spears, I like the two prong spear for one bale on the loader that I built last, it is a lot more stable and you can stab lower in the bale if you need two. | |
