Michigan | We have the same set up as you. We run from a ground driven pump to a bank of redball gauges. We have 15 of them, 1 for each row. From the ball gauge it goes down a 3/8 hose to a orfice fitted on top of a yetter coulter knife set up. Our sprayer dealer gave us the correct sizes based on the size of our bar, our desired rates, and our desired speeds. We run 40 psi at 7.5mph applying 35gal/acre | |
