Bow Island, Alberta | I bought a GS2 with rate controller and swath master (or whatever JD call theirs) to use with my FAST sprayer last spring. Worked flawless for over 100 hours. I think as long as your sprayer has Raven flow meter and flow control valve, then there's no problem. I think the JD book also lists Hardi valves that are compatible.
I didn't have to buy the Raven controller because the GS2 does the controlling. The only wiring I needed was the Raven harness to go from the flow meter and valve to the JD rate controller.
I also bought a set of flow meter/valve to use for liquid fertilizer on my seeding outfit. Haven't used it yet, but then I can change my fertilizer rate on the go while seeding. Should work good when seeding pivot corners the same time as the irrigated part of the circle.
Edited by willvr 11/25/2007 21:24
