Posted 12/3/2012 17:37 (#2730905 - in reply to #2730858) Subject: Re: DT 466
Ravenna Ohio
Had an older version that was a dog even after turning up. Pulled the turbo boost sensor line off of the manifold. Hooked it to the air tank via a pressure regulator. Told the pump the engine always had 25 lbs of boost. That woke it up.
