Posted 12/3/2012 16:35 (#2730834 - in reply to #2730749) Subject: Re: Looking at JD 4730 Sprayer. Good / Bad?? Can anyone run a serial #
Works great! went from an apache 1010 to one and cant believe the difference. Great machine, booms are sturdy and "float" well over terraces. If you end up getting, there are several updates or things to check but none of which should prevent you from buying one. Like, making sure drive shaft is as tight to the fly wheel as possible, replacing boom hoses at about 1500 hrs, ect.
