rrv, nd | Von, www.metalsales.us.com
is the company i bought it from, through our local lumber yard. Curveline is narrower than regular steel panels 2'wide, and the ribs are not as high probably 1/2" high. this makes it more flexible and easier to form to the curve of the roof. It is easy to work with, and was very satisfied with the results. It is also more expensive. It overlaps like regular steel, and screwed down. They will cut to length when you order it, so that makes it easier and quicker to install to, no cutting.
Edited by hellosugar 11/29/2012 20:59
(!cid__1129110956.jpg)
(barn 2011.jpg)
Attachments ---------------- !cid__1129110956.jpg (42KB - 483 downloads) barn 2011.jpg (40KB - 522 downloads)
