| With the wind here you could shut off the tank supply and remove the d=feed line
only do it the wind is blowing away from building s
if you pour into the feed line the methanol will bubble back out so don't get it on you clothes
safer to take a bath towel and poor "hot" water on it
make sure the vent on the regulator does not get sealed off
I f a lot of water might have got in the line might have to inject methanol at the tank end | |
