Search Forums | Classifieds (203) | Skins | Language
If you had irrigated sand what would you plant for most roughage and wanted to chop it?
BigNorsk
Posted 11/25/2012 18:31 (#2716546 - in reply to #2714002)
Subject: RE: If you had irrigated sand what would you plant for most roughage and wanted to chop it?
Rolla, ND
Ok, I misunderstood.
I would think sorghum-sudan would be an option. The thing is you add the cutting to the operation because you have to cut it to let it get to the proper moisture and then chop.
The brown midrib is higher quality feed but lower yielding.
