Iowa | One thing I will recommend is to take extra care when planting (or before) to create very good exterior and interior boundaries and guidance lines.
Once you create these with RTK, you won't have to ever create them again because they will not shift over time.
All you have to do is manage them in Apex correctly and you will have them forever, until you want to change them.
For the field leveling, it is recommended that you are no more than 2 miles away from your base station, because you start to lose your vertical accuracy at a much higher rate than your horizontal accuracy. In your future planning, you may want to make sure that you have the equipment to have your own portable base station.
