Mercer County, Ohio on the Indiana line | What about cutting a hole in the cap for where a joystick would go for a loader tractor? It's not in a very convenient spot but it would work and could be replaced with a new cap pretty cheap with no evidence of ever being there.
Or you could use the switch that is for PTO. If you don't have a PTO you could just use that switch or drill a hole behind the PTO switch and put another switch that is the same so it looks nice yet. That would be in a nicer position for using the switch.
Nathan |
