Cen IL | As far as the Precison Planting vSet goes, you will not find a more accurate meter. I have installed those on over a dozen planters in the past year and everyone is thrilled with them. The one thing to check is the hydraulic capacity of the tractor. With 12 rows I believe you will need 5 gpm flow or so. You will also need a case drain on the tractor to remove excess oil from the blower. The system is fairly easy to install, too. If you have any other questions my email is in my profile. Good luck! | |
