“These are the times that try men's souls.” | I cut a 5"x 2" PVC or a little bigger pipe and duct tape it to vert. fold down bars of side of squeeze chute. To put wormer gun in or can also put auto vac. gun in small pipe. With the duct tape you can move it around the chute to fit vets needs. Also a handy way to hang a 250 ml. bottle if using a draw tube is to cut a finger out of a OB sleeve glove and insert bottle in it, then tie glove on upper frame you can double up the glove if you think needs it to hold bottle. You can cut it down or rip it off in a hurry, I will make several up and have them ready to tie up if working a lot of cows. |
