Posted 6/17/2006 02:02 (#20003 - in reply to #19665) Subject: RE: JD 2755 clutch?
SE PA
Well, I did it like you'd normally bleed brakes.... First time, it dribbled fluid out of the bleeder a little. Next time it was less, and 4-5 times later it just made a 'sucking' sound as I'd open the bleeder with the clutch pedal out. I'm guessing that the master cylinder is shot. Soon as I get some time, I'll take it off and investigate that little critter.
