SW MN and Gold Canyon AZ | Go, don't worry about the pumpkins the cleaner at the plant will take them out anyway. If you have some pods then you are not overthreshing the good ones. Use plenty of air on the bins. I have air tubes on the side which help dry down the pods.
Don't worry about having a perfect sample from the combine its the seed quality of the good ones you should worry about. | |
