Posted 9/4/2012 14:07 (#2574669 - in reply to #2574355) Subject: Re: silage bags
Faunsdale, AL
Go buy a large size garden hose. You won't be able to do a lot, but it's probably worth it to run one when you're a bit (QUITE A BIT) dry. If I need the moisture, I tell the guys to leave it running between loads, but you have to watch out for any delays between loads and get it turned off.
