Alhambra Il. | I have the same truck with almost same problem talk to dealer wasTold injector were bad. I changed the lift pump still won't start . Now a different dealer tells me main veil pump is bad. a very small amount of ether and starts up In your case I have heard low voltage will cause them not to start. I think is more fuel shut off it runs to good. I am ready to pull what little hair I have out. | |
