Posted 8/15/2012 12:59 (#2540732 - in reply to #2540606) Subject: RE: Are Deeres load shaft seals better now?
I was told this winter that A&I seals where better , and that people where having problems with JD's. I used the A&I's and didn't have any problems. Make sure you use all new bushings in trans case and the yoke with new shaft and shim it as tight as you can get it.
