ecmn | does the loader chatter when you try to use it?
i guess if it was mine i would do a pressure flow test of the main pump then move onto flow test the transmission pump depending on what you find. very common for a line in the transmission housing there to pop a leak. the 50 series is a lot better then the 40 but still can be a problem. not bad to fix. i would follow the book on hydraulic testing, simple flow chart to follow and can save a lot of time later on.
Edited by easymoney 8/15/2012 21:34
