Posted 10/21/2007 14:53 (#223970 - in reply to #223795) Subject: wrong wheel speed cal # turned out to be my problem
I was having troubles with the yield numbers dropping when I lost the differential gps signal and finally figured out that the wheel speed cal number was wrong/way off. After I got the cal number in the ballpark everything worked fine when I lost the "D" .
