Seymour, IN |
I recently purchased a 1990 IH 4900 and a 16ft bed separately with the intent of combining the two and making a single axle grain truck. The bed came with the hydraulic pump, and hoist. The hydraulic pump is the type with the pump, valve, and reservoir in a single unit. I'm needing the cable that controls the valve from the cab. Does anyone have any information on where I can find this? I also need some help supporting the PTO shaft from the transmission to the pump. The shaft is roughly 1" diameter. The bed came with a unique looking bearing with a bracket built around a sphere with the bearing in the center. I have gone to a few auto parts stores around here without any luck. Do you guys know where I could go to in order to find both of these? I'm located 60 miles south of Indianapolis, you would there there are plenty of places to find grain truck parts around here. | |
