| On top of the block where the coils are on the right hand side is a pressure sensor, I had one that wouldn't adjust the pressure and showed it had pressure on it like your saying. I replaced the sensor and pressure would then adjust. Also had a couple that the whole block had to be changed on to work. but that eliminates that if the reel circuit will make it work. I'd try the sensor first. If it thinks the pressure is too high it may not let it work. When you swap the coils the reel circuit doesn't care how much is there, it just sends pressure. | |
