Effingham, IL | I don't remember having trouble with the gauges, but my rotor- ground speed-fan speed-engine rpm box would go nuts. It gets it's power from the small wire that runs all the way from the + battery post. I think they call it the "pure" wire. You might want to check it's connection on the + battery post. My wire was bad somewhere in the harness so we had to get power to it from one of the solenoids under the right cab panel. Craig | |
