Posted 7/20/2012 22:55 (#2497408 - in reply to #2497379) Subject: Re: Semi steer tire help
So. IL
I check the tires for run out after I install them with a 4x4 block on the floor and it seems like every tire has some run out in it, some more than others. If you are not sure about it, moving it to the trailer is a good option for it if you have the same size on it.
