Buffalo IL | I don't have one and haven't run one, but I have a neighbor that has one and the is year break where the gear boxes on the discs can be checked by taking out a plug with a dipstick I believe. Really check to see if the U joints and constant velocity joints are good on the PTO. You are looking at about $700 to replace a bad Pto shaft w Cv joint from what i understand. It may be higher now that is what it cost my neighbor afew years ago. You can mow as fast as you can stand to ride the tractor.
Edited by IL cow man 7/20/2012 10:28
