Posted 7/8/2012 13:00 (#2473383 - in reply to #2473309) Subject: RE: Killing volunteer corn with Fusilade and Crop Oil?
SWMN
Crop Oil will actually work better. The only thing you have to be careful of is if you are tankmixing glyphosate with the Fusilade that you use an oil that is glyphosate compatible. The normal 17% crop oil will cause antagonisim. I use Superb it is a high load crop oil that is glyphosate compatible and works good.
