Northeast Indiana (Auburn) | Looks like my 1250 IH grinder with the unload hight extension. I bought the two piece gear to bolt on the swing and made a bracket to hold an old orbit motor from a fertilizer auger. I made another bracket to hold another orbit motor and unhooked the small lever chain on the lift crank, put on a longer chain to the orbit motor. The only problem I had was about every 200 times or so I would shear the small pin that holds the worm gear to the sprocket shaft. It sure made it nicer to position the auger from the tractor seat. |
