Louise, MS | i have a bearing gone out on one of the 4 augers that is up under the rotor. and its the one thats towards the front of the machine. my question is the only way to get to it is up under the bottom by the transmission it think. can you reach all of them from the one spot bc theres not much room in there to work once you get o=in the hole? is it easy to do once your there or is it some special technique to do it? | |
