Posted 7/6/2012 13:01 (#2469738 - in reply to #2469630) Subject: Re: Use Dial-a-Matic on 600 series JD head
There is an adapter cable that replaces the single point connector, and as previously stated, you will need hydraulics to run the hydra part of the flex head. You will also need to update an electronic control board and install a hydraflex button in the cab. The kit from Deere or Lankota is necessary to make the head work the best.
