Posted 7/5/2012 19:32 (#2468549) Subject: Polaris sportsman shakes on road
central mn
04 polaris 600 sportsman, has terrible shake in it going down the road, starts bout 35 and kinda stops around 60. Tie rod ends were wore out and ball joints were shot, I replaced both on each side and it still shakes, wheel bearings aren't as tight as new, but not bad, is it possilbe that the tires could be bad, causing this to happen? Anyone have this problem and how did you fix it?
Thanks
