Posted 7/5/2012 00:00 (#2467303 - in reply to #2466835) Subject: Re: Converting a jd 1500 powertill seeder from 1000 pto to 540
W.C. Mo.
Different pto shaft. Might be able to just find a 540 knuckle that will fit the u-joint. Either turn or change gear box. Not sure about that drill but some other machines you could exchange input and output side to change speeds.
