| New rules require internal valves. Check on insurance guildelines, placarding, placement. Fairly sizable cost in saddles/mounting pads. Transports loads are going to be in the 9,000 to 9,500 gallons, and with a 86% fill capacity, can often get tight in getting a load in before the tank runs out. Line sizing will depend on vapor/liquid, amount needed, and length of run. Run 9 million BTU's on 1" steel with liquid, and 600,000 BTU's on vapor with 1" plastic. Also 500,000 BTU's on 1" steel. All 100' to 200' runs. | |
