Posted 6/19/2012 19:03 (#2438402 - in reply to #2437770) Subject: Re: 2630 and Commandcenter touchscreen AT issue
WC IN
The above posts are correct, when a 2600/2630 is connected all Greenstar functions (guidance, mapping, etc.) will have to be run through that display.
With the touchscreen command center, i've had several guys run planters and rate controllers on it and have been quite happy with that setup. Just split screen the 2630 and put a device on the command center and that gives you 3 areas that can be seen all at once
