Morris, IL | Do these motors require no return pressure? We do something similar with sides of corn crib. We plug hoses into remote and it has worked find for years, longer then i've been around to shovel it out. Also have a sprayer set up same way. Then again vacuum motor on planter requires no return pressure so it goes into case drain. Some motors need no return pressure and some need some, i think it has to do with speed it is turning but i'm by far some hydraulic motor expert. If you need one, i'd talk to older IH mechanic and pick his brain on where a no pressure return can go.
Edited by NEILFarmer 6/18/2012 21:47
