Eastern Iowa | I have a couple 48 loaders, one is sitting around unused at this time, I need another loader for a JD 7700 to load big square bales of hay in the field. This is the older version of a 148 loader with a single cylinder for the bucket. Will a 48 fit my 7700? Are the frame rails the same on width as a 4020? What is the preferred way to get loader controls? I have triple hydraulic SCV in back I've done it that way on a 4430 or should I get a a joy stick control and tap into pressure lines somewhere? If I go with a joystick which ones should I consider | |
