haskell county, ks | what kind of nozzles are on the pivot? all of our sprinklers have drop nozzles and low drift nozzles. we only need about 10# at the end of the sprinklers to have very good patterns. i'm like agriman, would love to have that kind of water in a sprinkler. you have huge water and rainfall and a lot of ours pump 350 and very little rain. more than likely your pump wear is resulting in low pressure. if you speed your pump up, does pressure return? if your well is not having enough yield, your pump will pump air. if you are pumping air, address the well, if not probably the pump. leaks can easily be seen. | |
