There have been times when I find a page of information that is interesting and I'd like to print it or copy it and forward it. However the page is filled with ad's and miscellaneous junk.
If you find a page of recipies that you'd like but don't want all the other junk click on the address or double click which ever turns it all blue or what I call highlighted. Next press Ctrl and while holding it down press the letter C on your keyboard. That will copy the address.
Now go to the print friendly page and where it says "enter a url" click in the box and press Ctrl and while holding it down press the letter V. That will paste the address in the box. Then click on black box that says print preview.
That should give you a page you can print without all the junk. And if you want to copy some of the text it can be highlighted and copied, then dropped into an email or letter.
Prep Time:
20 Min
Cook Time:
10 Min
Ready In:
30 Min
Ingredients
- 1/2 cup butter
- 2 teaspoons garlic powder
- 4 cloves garlic, minced
- 4 pounds beef top sirloin steaks
- salt and pepper to taste
Directions
- Preheat an outdoor grill for high heat.
- In a small saucepan, melt butter over medium-low heat with garlic powder and minced garlic. Set aside.
- Sprinkle both sides of each steak with salt and pepper.
- Grill steaks 4 to 5 minutes per side, or to desired doneness. When done, transfer to warmed plates. Brush tops liberally with garlic butter, and allow to rest for 2 to 3 minutes before serving.
