Southcentral WI | I would say in sandy soils you should be fine, but any smaller particle soil with more clay in it and you'll be in trouble. 8530 would pull it fine, where we are there are so many different soil types even in one field that performance varies. Slope also plays into factor on a setup like this too. Plus, if you ballast the tractor properly you will gain more of the HP to the ground....I've seen improperly ballasted tractors struggle to pull anything, but when ballasted properly, they pull almost anything!
