Ft. Wayne | I wouldn't be afraid of it. 1.5 oz was the low rate we used to run with Balance Pro tank mixed with the atz premixes. So you are going to add 0.7 oz to an already lower rate of Corvus. good way to use up some old chemical. If you were talking max rates I might be nervous. I have seen corn bleached white from Balance, but not with the lower rates. And I would NOT do it post emerge, preemerge fire away. | |
