Eastern NC | We used to run a spreader similar to that several years ago on the rear of a 6500 Deere sprayer to overseed cover crop into the cotton fields before we defoliated the cotton. The spinner was driven by a hydraulic motor that had a valve hooked to the spray pump switch. The flow of seed was controlled by a hydraulic cylinder on a slide gate. That cylinder was hooked to the right hand boom raise lower switch. Do your spinners run all the time or are you turning them on and off to shut off flow of material. It seems that you could simply hook an air line from a rear air bag to the pressure sensor to fool the low pressure alarm. You will need some type of custom harness to tie into the plug on the rear of the sprayer since you removed the boom. What is actuating the on and off of the spreader flow when you turn on the ends? | |
