NW Kansas | My 4420 is run by an insight display and I believe it has all agleader stuff, steering, section control etc. Even has a peek-a-boom remote system and AIM. About a month ago I lost the ability to manually turn my boom sections on and off. There is also a delay in the booms coming on. Example: If I turn my master switch on with all my boom sections on, it takes about ten sections for the light to turn green and the booms to come on. Then if I shut my master switch off, the booms will not turn off at all unless I turn all of the section controls off. Even if I turn the master off and six out of the seven sections switches off, the entire boom remains on until I turn the last section switch off, at which time the entire boom shuts off. Now, if I spray one round of a field, then use autoswath, it works just fine turning individual sections on and off. Been a very frustrating and troublesome problem that I need to find a solution for!! Any Ideas? Thanks! | |
