Central Kansas | Putting down 5 gallons of 10-34-0 with TT mounted in the insecticide tube bracket. Finding that after a few acres, a ball of mud/dirt is forming on the little rubber tabbed bounce stopper that is directly behind the seed sensor and have a feeling that this "ball" is dragging the seed with it and spacing is not the best(I know, it's a blow planter). Anyone else experience this and if so, what did you do to fix the situation?............remove the rubber tab or replace the TT's with something else? | |
