NW Washington | Fully loaded without ballast the 36 footer weighs about 28,000 pounds. The openers don't take much power to drag though the ground. You might need more hydraulics to run both the downpressure and the air delivery fan. I know an 8400T will pull a 30 footer on some of the steepest hills in North America without much of a struggle. Check out the spec sheet on JD's page. http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=Ag&p... | |
