Search Forums | Classifieds (151) | Skins | Language
JD 9600 Tachometer
txcwbysa
Posted 4/22/2012 22:36 (#2349628)
Subject: JD 9600 Tachometer
The tach on my combine doesnt come on. NOthing works on it. I put a volt tester on the 10 pin plug and I get voltage on 4 of the pins when the combine is running. ONe is .41, one goes as high as 3.8 and one varies btw .25 and .50 and the last has voltage but I cant remember it. Does anyone know if my tach is not working or what might be going on? Also, is there a fuse for the tach and could that be the problem? thanks for any help
