| Only 29, I don't think you'd have a problem with it sitting outside. Probably will only be below freezing for a couple hours since it usually drops a couple degrees around dawn (where the true "low" typically happens). Most the night will likely be around 32 degrees. In the shed, you probably wouldn't have a problem until it dropped to around 20 degrees outside for a low considering how warm it has been during the day. Especially if you are talking 2" or larger lines on a larger sprayer. That's a lot of water to cool down and freeze. At most, close the sump, blow the water out of your booms, and drain the pump. The tank will be fine.
If you don't have boom clean-out on your sprayer, plumbing in an airline you can connect your air compressor to makes quick work of cleaning out your booms. Just make sure it has a check valve. | |
