Clinton, ON | If u can find a tanker that is properly galvanized that is usually your best bet. They will not rot from the inside. Also check what pump they put on. I have 2 tanks, 1 with a 11000 Jurop pump the other with a 13400 liquid cooled BP. The BP equipped tanker also has a helper pump in the suction arm. This one pumps a lot more per minute but can handle also a lot thicker manure then the Jurop. | |
