Grays Creek, NC | We had a 5140 that does the same thing only in 3rd range...under the right hand side of the cab, where the linkage from the shifter goes into the transmission, there are several small round sensors on the linkages that have to line up that will kick it into neutral if they arent all the way in gear. We adjusted these and it has worked fine ever since. Hopefully I did a good enough job explaining this | |
