Posted 4/5/2012 22:46 (#2323121 - in reply to #2322699) Subject: RE: Spraying behind Planter
Greene Cnty, SW-IL
Used to have a dimmer switch bolted to cab deck. Now have a foot switch called something like 'clipper switch', it's heavy, stays put but just lays on the deck. Call Jensen Equipment in Newton, IL. Phil can send you just what you need. I preferred a sperate control from planter position.
