Mid-East Nebraska | Engine must be running: Press and hold the vehicle settings switch and the lower hitch set switch simultaneously on CommandCenter™ within 5 seconds of power-up [key switch to the START position (engine ON)].
Engine does not need to be running: Press and hold the vehicle settings switch and the lower hitch set switch simultaneously on CommandCenter™ while turning the key switch to the RUN position (engine OFF).
